FW 3.1.20.006
Muxlow
Super Secret
Middlesex County
Im thinking so
Just loaded it into my test radio and read the codeplug. Seeing a couple new options such as a
SFR mention under digital common - basic down at the bottom has a SFR auto select thresh hold and offset options. Was told SFR will be added to H series so perhaps in the next FW that will be seen
Full encrypt - private - Hyteras version of AES (Paid upgrade)
Full encrypt - standard - standard version of AES (Paid upgrade)
TTS (Assume text to speech Paid Upgrade)
Under a digital channel i see a grey out box that says Access protection type and access protection key...wonder if thats hyteras version of RAS
For mixed mode under digital channel seems you can select if you want the radio to transmit back in digital or analog too when the mix receive is checked for each channel
  • Like
Reactions: a2s
