FYI - County Center Points
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hi all,
You may have noticed that the entire state in the database is green today, but you can't see what I updated. We are in the process of updating each county within a state with a geo location. This will cause any entity within the county, which does not have a geo location attached to it, to default to the county center point.
