G.p.i.s. Tg 880
Macomb, Michigan
I have G.P.I.S. programmed in my scanner and have the all the PD'S and FD'S in there and no wildcards but my scanner for someone reason picked up TG 880 which is Gross point Shores DPW which I never programmed in there. So my question is, even if you do not program a wildcard in can my scanner still pick up a wildcard.
PRO-106
rdale
Lansing, MI
You must have a wildcard programmed in there somewhere, or you have TG880 in.
Macomb, Michigan
Now I'm picking up another one TG 912 Parks Rec. Pier Park. I just really don't recall putting one in there. I just find it odd because I've been listening to GPIS for the past week and all of a sudden it's picking up wildcards. Go figure.
I know they moved over to MPSCS and should be done soon from what I understand. Anybody know if they have completed the transition yet?
freqs
warren michigan
They have not made the move yet .What you are monitoring is still the Eastern Wayne System or G.P.I,.S .
On my Scanner it is still showing it is Apco 25 3600 Baud 801c
