G3 Two-Tone Paging Question
jmalecki12
I'm very new to programming pagers and I've been run into a common issue with the programmed pager activating when it's not desired.
For example, the pager is programmed with TONE A: 669.9 & TONE B: 746.8, but it's triggering when Dispatch is actually toning out TONE A: 788.5 & TONE B:669.9.
Does this make sense? To be honest, I may be wrong as I can't exactly reproduce the issue.
Is there a way to easily fix this? Anyone have helpful input for me?
Please and thank you!
hazrat8990
Wyoming
Since the tones are nearly identical, or at least fall in the same range while setting up your sub groups, you may have to play around a bit with the protocol parameter settings on tab E-4.
hazrat8990
Wyoming
QCII are one second/three seconds, so you'll have to add, or subtract from the tone qualifying setting. Maybe set tone A to 500ms and see what happens.
