G4 Alert tone
chstewart
I am setting up G4's and have ran into a issue getting the Alert tone on two tone activation P25 phase II. The pager opens up on the tones and vibrates and will record the call but I do not get the alert tone it just opens up and I hear dispatch. Alert Mode is set to tone and vibrate in both group ID and zone channel settings. Am I missing something? I have tried the tones that are built into the pager and have downloaded costume alerts nothing seems to work
RBMTS
I had the same dilemma at one point until I watched the programming videos a couple of times. On tab 4 (Group ID Settings), highlight the talk group that the paging will be done on. Not the 2 tone frequency sroup you created but the actual trunking talk group. In the column for "Alert Tone" select "Default Tone". Save your profile. Do this only on the talk groups that will have tone decoding on them. Don't do it on talk groups that will just be scanned. Reason being that you'll get a beep every time it receives the talk group. On TG's that will be used for 2-Tone, you won't get the beep.
RBMTS
You stated you already setup the tone parameters in your first post. You set the actual type of alert tone you want you setup the two-tone pair (for conventional) or the A/B tone ranges (for trunking). Perhaps that is the problem that you have "None" as the tone and therefore it just opens but not alerts. There are two very good "how-to" videos from Unication that show how this is done. But the key thing is that if you are two-tone alert on a trunking group, you must set the Alert Tone box to "Default Tone". If you have "None" listed, then the page will just open and receive as you indicated in your first thread.
chstewart
Found my mistake thanks
