G4 Clear Recorded Audio
fwfdengine2
Bloomington, Minnesota
#1
Hello,
I have a bunch of recorded audio in my replay button that I want to get rid of. How do I go about this? I googled/searched RR and cannot come up with the answer.
Thank you.
troymail
Silent Key
#3
As Richard noted, you can delete recordings using the MBox (RED) key. However, there is no harm is leaving the recordings - they don't hurt anything and it's a circular buffer that will be overwritten after you have 1,000 recordings.
If you don't want recordings at all, you can turn them off with various settings in the PPS.
Michigan
#4
Ever since the phase II upgrade my G4 has been ending recordings silghtly early causing a word or two to be missing from the end of a transmission. I've tried turning triple buffering off however that did not fix anything. Is anyone else having this issue or heard of ways to fix it?
