G4/G5 and ADP
FJB2022
Has anyone successfully programmed a G4 or G5 that receives ADP on a P25 Phase 1 or 2 simulcast system? I've been unsuccessful along with one other person on another forum. Thanks.
FJB2022
If it’s a legitimate key it should work, you need the key loader
I have legitimate keys and the key loader program but have not been able to get it to work. Someone else on a different forum said they could only get it to work with simplex but not over a repeater.
WX4JCW
Stow, Ohio
you have to set the id number in the security tab in the PPS, when making a channel knob entry just above the talkgroup selection there is an encryption check box also in the group tab make sure the proper key is listed
FJB2022
I think the encryption check box is my issue. I will be able to test it this evening. Thanks
wa3ysu
Central Bucks County, PA (Near Phila.)
Works great on AES and ADP. Be sure to enter the full 10 (ADP/URC4) or 64 character (AES) key. You need to be certain to have the correct CRK/Key position that is used by that agency. You can have the right key, but the wrong position ID, and it will not work.
FJB2022
Thanks for the info.
