G4 on aitkin system
JASII
I doubt it. It is likely a setting on the Unication G4. Connect it, with the programming cable, to a computer running the PPS and change the setting.
peq387ab
Central Minnesota
No it isn’t. When you program your G4, under each individual talkgroup, under number 4 “group ID setting, and then you will select none for the alert tone.
