G4 programming issue
meowmix9350
Peotone illinois
picked up a g4 the other day, cant get it to connect to the computer no mater what i do. I have tried numerous cables, the driver from the site, changed settings in device manager. so on and so forth. when I plug it into the computer I do not get that connection sound however the g4 begins to charge no issue. wondering if anyone has had a similar issue and had a fix potentially. thanks.
BenScan
D/FW
Yes. I've had it happen. Once the USB port was bad, and it had to be sent in for repair or replacement. I don't recall now. More recently, I've effectively bricked one of my older G5s when programming, and had to revert to an older firmware version(2.02 back to 1.35) to get it to come back. In that case, the firmware update software would connect, but PPS would not.
I'd start simple though, and try another computer, and then another cable that you know works. Hopefully, it's just a bad or incorrect cable. I'm assuming, you're using a home computer and not a work computer where your IT department might have turned off your USB ports. Recently at work I was trying to use another radio brand's programming software and it wouldn't connect until I turned off some other network connection software.
K9KLC
Southwest, IL
I have older G5's from I guess about 2019. So far, they've been ok on 2.02. Did the bricking happen right away or was it something that came up later?
To the OP, yes try a known data cable or even another computer and see if that helps.
meowmix9350
Peotone illinois
I have tried 3 computers and 4 known data cable 1 being brand new from unication, firmware software and pps does not see it nor the 3 computers, starting to think maybe bad usb port just found it odd that it will charge no issue but no communication.
meowmix9350
Peotone illinois
on another note the warranty is good until 27 on my unit however it was bought second hand, how do I go about getting it in for warranty work?
BenScan
D/FW
Reach out to Unication or a dealer. It might be worth buying a drop-in charger to reduce the use of the USB port, and might encourage a dealer to help you out if you have any issues with it being second hand. I highly recommend Ray's Pagers.
BenScan
D/FW
Recently, I suspect it's because I'm trying to cram too much, including about 9000 Subscriber IDs/aliases along with the huge number of trunked systems.
Nascar18
Southeast Massachusetts
Just checking is the G4 powered up when connected? It has to be powered up for the PPS to connect, G4 will have PC connectedon the display. It will charge when powered off.
Yes it’s powered up, have a bad feeling usb on g4 is shot for data.
I agree with @jtwalker it is very likely the cable.
However, this is a windows computer you are using, correct? Have you tried another cable? Have you tried another USB port? Have you checked the "DEVICE MANAGER" to see if it is showing and then clicked on properties to ensure the proper driver is installed or if errors are showing? YES I know you said you installed it from the website, but have you checked?
meowmix9350
Peotone illinois
Yes i have done everything you listed above, when i plug the g4 into the computer (and with several cables) the computer doesn't even see that anything was plugged in at all, replicated this with 3 different computers.
