tvengr
Well Known Member
Anyone else seen this problem? When pager is turned off, 3 red LED's on top light and stay on. Pager reboots when turned on.
Is the G5 working with the LEDs constantly lit? Or not working at all with the LEDs lit? I'm pretty certain there was an LED bug that was fixed in a firmware update a few years ago. And you're getting this problem with V1.33?Still doing the same thing.
I can't imagine a reason you would want LED's to remain on with the pager off. Ray's Pager Sales is not sure why the 3 LED's would stay on.. is it possible that you might need to change the settings in the PPS to get these LEDs to not remain lit?
Quite true. Got too bound up in why they were on--forgot they remained lit when off... Sounds like that G5 is going on a trip--sorry for your troubles.I can't imagine a reason you would want LED's to remain on with the pager off. Ray's Pager Sales is not sure why the 3 LED's would stay on.
Pager has the latest firmware. I updated the firmware and problem still exists.Early firmware versions caused the LEDs to remain lit.
This was a replacement from Unication to replace another G5 which met an unfortunate demise. Pager has a brand new battery which originally had about half a charge. I fully charged the battery and it still has the problem. I have pulled the battery and replaced it a couple of minutes later with the same results. When placed in the amplified charger base, the other two lights go out. The charge light turns green with a full charge. The pager also reboots every time I turn it on.Yes I have had that issue a few times. Usually I have that issue if I let my pager go dead. What I have found to be successful with troubleshooting is either pull the battery with the pager in the off position and let the battery sit out for about a minute or two and then put back in and leave the pager off and charge the battery from scratch to full charge. Otherwise I have had it go like that and put it into my cradle and it came back to life. I’m guessing all three LED lights on top must indicate completely dead battery
Very rare for my G5 to reboot when powered on—it usually only reboots after firmware update or events like that. My G3 reboots every time I turn it on and I’ve been told that is normal. Sounds like your replacement G5 has an issue that needs to be addressed by the dealer.The pager also reboots every time I turn it on.
Will do!Please keep us up to date on what happens Thanks.
