G5 audio playback
TxScanner
Can someone please explain the steps, on how I can replay audio I heard on the pager while scanning, and I missed what they said and I want to replay and listen to it again, basically like the replay feature on the uniden scanners, thank you
N6ML
Assuming that you have configured both the knob position and talkgroup (if applicable) for "Voice Storage", you can just push the play button (in the center of the select knob) to play back recorded messages in reverse order (i.e. most recent first). You can also use the red square button to enter your "Message Box", where you can navigate through the list and play individual messages (with the blue triangle button).
Unfortunately any new message received will preempt playback, so you may need to "get to a quiet" place (knob position with little or no traffic) to be able to play back without interruption.
TxScanner
perfectly honest, i don really dont know about programming these things, i had mine programmed for me. But from what i looked at in the PPS, i went to D5 and it showed a check mark in all the boxes, and when i went to D6 and clicked on the zone for knob position 1, and scrolled down, i saw voice storage, and it is off, with the only options as being OFF-ID MATCH, no "On" or enable.
N6ML
You want "ID Match" for P25. CSQ has an option for "All Voice".
WX4JCW
Stow, Ohio
That tiny button on the top of the channel selector
WX4JCW
Stow, Ohio
If the programmer uses the radio reference import , voice recording defaults to off fyi
TxScanner
I just attempted to work on it, but it’s not saying connected to PC when I plug it up, it always has before, never had this problem, Yeah it makes the sound on the computer when I plug it up, but not doing anything on the G5 other than saying charging when I have it turned off, but nothing happens with it turned on connected to computer
TxScanner
Rays pagers programmed it for me, and it was before the radio reference update
WX4JCW
Stow, Ohio
you may have to install the drivers, unplug the radio install the drivers then plug it back in, it will not connects until the PPS is running and you should see the screen blank out and say "PC Connected" with a green check
WX4JCW
Stow, Ohio
here arte the correct settings for having voice storage
TxScanner
one last question, so, i think i remember it only recorded 10 minutes worth, so after it fills up, does it record over the older stuff? or do i have to go into settings on G5 and delete them manually? Thanks.
WX4JCW
Stow, Ohio
it will overwrite the older, you can pretty much do whatever you want (let it sit and overwrite or delete them doesn't matter), they even have a message backup software you can download them, but it does need some serious work as it has a lot of informational bugs
TxScanner
OK, found another question, sorry. Is there a way to turn off the sound that beeps when you do a playback
WX4JCW
Stow, Ohio
you can turn the alert tone volume down and yes it will scare the poop out of you
TxScanner
If you wouldn’t mind, would you give me the steps to do that, I’m not sure. Thanks
WX4JCW
Stow, Ohio
section D-8 i usually set it to 3 but you can turn it off too
