G5 Belt clip
kg4pbd
I must be missing something, but I can't see how to remove the belt clip. I"m afraid I"m going to snap something off here. Any thoughts?
IAmSixNine
Dallas, TX
Top of the pager. The part where the pager clips to the back of the beltclip is a is a small piece of plastic that clicks in when the clip is seated properly. Use your finger or flat head screw driver and pry it away from the scanner and your clip should then slide up and off.
troymail
Silent Key
Be careful pulling on that little tab! Bend it only enough to slide the clip off...
Not knowing, I bent mine too far in the early days and then every time I used the belt clip after that, I'd find my pager in the grass in my yard.... one time while working on an in-ground pool (which could have turned out much, much worse!)
With guidance from my vendor, I found I could push it back to make it hold a bit better but I just don't trust it anymore...
Now, I just don't use the belt clip.
TwoWayTim
Oklahoma
ALL G series are IP67. If you drop it in a pool just dont leave it there too long.
Jimco
Dallas/Fort Worth
Thought I'd add that Unication's leather holster is a great choice. It's a really high-quality holster, and the belt clip is the exact same clip used by first responders in the field. Everything from the snaps to the rivets to the stitching to the quality of the leather matches with the superb quality of the G-series pagers. Just offering another option.
