G5 desktop amplified charger question
bobruzzo
W1AV
Cranston, Rhode Island
I bought this charger to not only use as a charger, but want to use it for amplifying the sound. I have been using my G5 at work to listen to, but the audio from the pager speaker is not too loud. I was using a bluetooth speaker but that wasn't working too well. I am kind of worried about leaving the pager in a long state of charging while listening to it. I know most modern day electronics will turn off charging when unit is at full charge. But will this shorten battery life using this charger for listening thru the built in speaker?
w2lie
New York DB Admin
Long Island, NY
Hi Bob
Make sure that pager is fully seated in the amp charger. Looks like it's canted to the side a bit which makes me think it isn't fully seated. You should open the belt clip so that it fits over the clip on the back of the charger slot. If you lift up on the pager it should take the amp charger with it.
I wouldn't worry too much about leaving the pager in the amp charger. Mine has been sitting in the amp charger for years.
K9KLC
Southwest, IL
I have 2 G5s. One spends a lot of time in the charger and the other goes with me every day. Both batteries were new in late September 2024. When "the wife's" comes out to play we can tell no difference in battery life between the two pagers.
About once a month I make sure to run them both pretty low and then charge them back up and use on battery as needed.
As @w2lie said and I mentioned in another post, make sure to open the belt clip when you insert it and then make sure it's locked in place similar to what you would do hooking it over your belt.
