G5 Ignored Traffic: UserID=0 on P1, P1 TG on P2 System
#1
Unication_David- could you let us know the plan to resolve the issue where the radio ignores traffic on a TG if there is no user ID/UserID=0? This happens with some dispatch consoles when they key up.
Also- should the radio be able to follow Phase-1 TG traffic on a Phase-2 system? There is a predominantly Phase-2 TG system I monitor with a few phase-1 TGs and the radio is not tracking those P1 TGs.
Thanks very much. . appreciate your level of engagement on these forums!
cpetraglia
Fairfax, VA
#2
I have a G4 and have been monitoring 2 local PII systems that do occasionally have some P1 TGs. I have them entered as they appear here in the DB. I don't here much, but at least I know that when the FW update comes out it should be good to go. I would also try 'Monitor Mode' and see if that gets a little more activity. No reason why it shouldn't work.
#3
Great suggestion re: monitor-mode! I find that the radio is hearing P1 TG traffic on the P2 system, but it is missing the P1 traffic when there is no user-ID coming through on the P1 TG (I know this from doing side-by-side tests with my Unidens), just like I had found on systems that are fully P1.
cpetraglia
Fairfax, VA
#4
I cant remember ever seeing that with my local systems. Do you have the TG entries you want to hear programmed in the Pager? How can a radio affiliate if it has no radio ID assigned to it?
#6
I do have the TGs I am interested in programmed into the pager. I am not a P25 trunking SME, but it is always a dispatch console that has no ID, vs. a mobile unit, and I know some dispatch centers use a data-link or trunk to the system-switch instead of an RF radio for access. I believe that is the scenario that can result in no UserID showing up.
#8
Sorry for all the posts. . but also for what it's worth, I have only noticed the ignored traffic on mutual-aid TGs. . this issue with no user-ID could be related to cases where the transmitting agency is patched in from a different system other than the native system being monitored.
#11
Monitor Mode may or may not solve that problem. It's got me stumped.
I appreciate the suggestion. However Monitor didn't solve it, unfortunately. We have an active multi-agency incident right now on a fire mutual-aid channel where the City I live in (and monitor their P25 system) sent an engine in to back up an adjacent fire department, who uses the separate State P25 system, and the only unit I hear is my city engine that responded. . all of the other apparatus whose home system is the State P25 system is not being followed by the G5. . (no user IDs showing up for the off-system units) . . but the Unidens on the same City P25 system are catching all of the traffic on this same fire mutual aid TG.
So. . I guess it's not limited to dispatch consoles but also includes field units. . common thread appears to be no Unit ID and that may be related to off-system users that are patched in.
Unication_David
Unication Representative
Raceland, KY
#12
Currently the unit sees the traffic from the 0 SUID but it will not open up because it sees 0 as an invalid suid and therefore ignores it we will be releasing a patch for this issue I cant say when but I will inform everyone when that happens.
Dallas, TX
#14
I too can confirm that the unit will not pass audio. I monitor a local system and they too have the dispatch consoles for both police and fire set up with a user ID of 0 and the pager does not pass any audio or recognize its an active TG.
I have verified this with another radio and with unitrunker.
Thank you Unication_David for working on a patch for this issue. I know i emailed you a few months ago about that exact same thing so its nice to see we are being heard.
I would like to also thank Unication for having a member of their organization on this list listening to us.
The whole pager line was meant for a different category of users but they appear to be receptive to us scanner people.
#15
+1 . . I am also impressed with Unication's support and willingness to take input from us hobbyists. Hopefully we do add value in finding nuances that will help improve things for the first-responder crowd as well :)
Also appreciate your reply IAmSixNine confirming you observe the issue also. .
Thunderknight
Bletchley Park
#17
David, any update on this patch? Another major user in my area is migrating into this new areawide P25 system and their console traffic is all RID 0 because they are patching from the old system for users who are migrating.
Unication_David
Raceland, KY
#18
We have a fix for this issue in Beta and we are going to integrate it into a future release.
