G5 - "No Device Connected"
stevez97
Myrtle Beach, South Carolina
Tonight I wanted to "tweak up" some of my G5 programming and received a "No Device Connected" message.
I am using the original Unication cable. I re-booted the G5 and rebooted the PC. Same result.
I'm using V0.3.12.6 PPS.
Might I have a cable that has gone bad? Any other suggestions?
Thanks in advance for any help!
JD21960
ILL-annoyed
WHAT is telling you no device? the PPS or Windows talking about the USB not being recognized? If it's the PPS you have to plug the pager into the USB, set up on the PROGRAM page and then TURN IT (*pager) ON till it shows "1" in the device above. Sometimes you must turn the pager off, then back on for the PPS to recognize the device to show (1) instead of (0)
If you're talking about Windows? then you might want to review the 10 steps in the "search" for RadioREF about Windows and unsigned drivers and how to turn off the protection for such drivers.
picscan
CA
If you have more than one port on your pc try a different one. Oh yeah ^^^^^^^that too. Turn the pager on.
CM1
Central, NJ
Win 7 / G4 here and this is how I get my set-up to "talk". Plug in USB to PC first, turn on radio (give a few secs to boot). Connect mini USB to radio. Open the G-Series PPS. Connected device shows as 1 every time.
Might be worth a shot.
bob550
Albany County, NY
What operating system are you using? Have you done any system updates recently? Turn the G5 on, plug the cable into the G5 and then the USB port. Make sure your speaker volume is on. Listen for the Windows device connection sound. Access Windows Device Manager and check the entries under "Ports (COM & LPT)" to see if Windows acknowledges the connection. If your computer does not recognize the connection, the problem lies with either the cable (doubtful unless your cat chewed it) or the driver. You can verify the operation of the USB port in question by plugging in a USB flash drive or another USB device. If the computer does recognize the connection, the problem lies elsewhere. Try cleaning out the micro USB connector on the G5 and the affected computer USB port with compressed air or a small brush.
N6ML
The G5 does not show up under "Ports (COM & LPT)", but under "Network adapters", because it uses RNDIS (Virtual Ethernet over USB), not a virtual COM port.
W4TF
FL
Sorry to hijack the thread, but didn't seem right to start a new thread for the same/similar issue.
Mine is no longer showing up in the device manager as illustrated here. I've tried reinstalling the PPS as well as rebooting the pc, both with no luck. Any ideas on next step(s)?
N6ML
Does it show up in if you enable "Show hidden devices" in the View menu? If so, maybe right-click it and select "Uninstall device", then re-run the PPS installer. It should reinstall the driver. Once it does that, you can quit the installer (don't need to actually install PPS again).
You could also try a different USB cable, and a different USB port.
Does windows make the "ooh, you just plugged something in" sound?
stevez97
Well...........I FINALLY got to troubleshoot this. Looks like the drivers must have gone bad. I downloaded the driver and it connected fine. While I was at it, I updated the firmware and PPS (with no challenges at all) and am up and running with the updates.
Thanks to all for their help and input!
