G5 not displaying correct MDC1200
N6ML
It worked at one time. It worked in earlier firmware versions, then stopped. I don't see it as a software problem, but a firmware problem that hasn't been addressed.
Do you remember which version of firmware it last worked in?
TonkatoyLFD
Your probably correct. More likely the software is doing what its supposed to but theFW in the radio is not.. Again, its already there and was working at one point. Fixing it shouldnt be hard. It has been 3 days since last communication with Unication. Im beginning to loose confidence.
N6ML
Is this really a critical issue? It's not preventing you from getting alerted, right? I wouldn't expect an instance fix for something that's mostly cosmetic.... or am I missing something?
TonkatoyLFD
Critical? not really. However it is very important to my organization. It helps us identify units operating at a scene, and even helps with accountability. Another department local to us had a FF go down at a working fire, his mic was damaged, RIT teams were able to figure out who it was and where he was operating by the Identifier. it not critical that it works on my G5 as it does work on all my other radios. That said its ability to display MDC was a major feature that was considered when the unit was purchased, may have opted for a different less expensive option if i knew that this didnt work. Its like buying a brand new car and having the glovebox light not work, is it critical? no. does the car still get you to wear you need to go? yes.. should it work anyway? yes....
APX8000
Sarcastic Member
AES-256 secured
Well....your RADIO should be displaying the MDC ID, which I further recommend alpha tagging in all the radios, which would give you an immediate notification of who it was. A G5 pager should not be used this way, and it doesn’t have alpha tagging ability with MDC, which would add another layer of what trying to decipher a HEX during stress. That’s why I also recommend pre vs post MDC because if they key up and can’t speak and just hold the mic, you are not getting the ID until the TOT kicks in, usually at 60 seconds. So while you would like it to work, and I’m sure in a future update it will, it is by no means critical.
brndnstffrd
CT
Not to take this off-topic, but the G5 doesn't have the ability to do alphatags for MDC? They mentioned MDC as a feature, but this is the first i heard about no alpha tagging as i just assumed it would do that. That would be a major factor in my decision process for purchasing like TonkatoyLTD
TonkatoyLFD
I can live without alpha tags in my instance as each radio carries the apparatus identifier and then radio number which is located to a certain team.. example the rig is 1-6-7 radio ids as 1671 meaning radio 1 off of 167. radio 1 is always assigned to a specific team. so the simple identifier says plenty to me. But i can see how alpha tagging would be a great feature in most instances.
Citywide173
Attleboro, MA
The only problem is that Radio 1671 has it's ID programmed as hexadecimal, which will show up as 687 in decimal.
TonkatoyLFD
Pretty much.... If the G5 would display Hexadecimal like its supposed to when that format is the selected display format then all would be just fine. Problem is the software lets you select the format you want displayed (decimal or hexadecimal) but regardless of what you select in software the G5 always displays Decimal. Again, its something broke in the software, or firmware. the fix should not be difficult. This issue was brought to unication from myself and my unication dealer, they are looking into it. Seems like a pretty canned BS reply to me. especially since days have gone by and no update has been provided. First dealings with unication and to this point i am not impressed.
Citywide173
Attleboro, MA
It has been brought to their attention before. I just don't think it is as high a priority as some other issues like P25 Phase II or DMR. You also have to realize that you are only the third or fourth person that I have seen who would like to see this fix, so it may not even be an issue to most customers. The Unication business model is professional users who buy in bulk, not individual users. Unication reports that only 1-2% of their sales are to individuals, so the casual user doesn't have a lot of juice when it comes to things like this. If it was an issue for MPSCS users, you could bet your butt that it would have already been fixed.
APX8000
Sarcastic Member
AES-256 secured
You and your dealer have brought it to their attention. After “days” you haven’t gotten an update and are not impressed. Do you honestly think that you, one person, is going to make their programmers write code to fix the firmware in that timeframe ? Lots of requests have been made for things like talkgroup hold. Even that is not a priority and has still not been implemented where something like DMR has. It’s all about their “entire” customer base, not just “you” the individual user. Not impressed....look at all the bugs with Uniden models. Many still in that list. But I’ll put my Unication up against any scanner when it comes to LSM and it will kick it’s ass everytime.
