G5 P25T proper wildcard
DaveIN
Founders Curmudgen
West Michigan
#1
I've been reading conflicting information in the help file vs. on these threads about wild card TG's.
Is there a correct method to hear un-programmed TG's via wildcard on P25T (trunked).
DaveIN
Founders Curmudgen
West Michigan
#3
I guess you mean set from the G5 menu, not the PPS software?
Edit: that works for my Freescan P25T setup when set to monitor through the G5 menu. Thanks for the tip.
