G5 programming matrix form
DaveNF2G
Cohoes, NY
I just acquired a secondhand G5 and it came with a partially filled-in paper programming matrix for the Zones and Button Positions.
Is this form available somewhere so I can print a blank one? I didn't find anything like it on the Unication website. I think it would be very useful for planning out my setup ahead of time.
What you have, most likely, is from the PPS, and you can not print a blank one, only one with programming info from the codeplug. Open the codeplug for editing, and scroll to tab E18 in PPS V4 or 11 in PPS V3.
jgorman21
Glenmont N.Y.
Dave,
I'd be happy to share a code plug. Of course it won't be set up the way you want it. But you can always edit and update.
73's.
Joe
DaveNF2G
Cohoes, NY
Thanks for the info. I created a new codeplug, so I can print what's there and the form will be almost totally blank at this point.
DaveNF2G
Cohoes, NY
OK, I still don't have a working codeplug. I think I need to configure options that I don't intend to use. The error that gets logged is that some parameter is not set to an instance of something.
I did figure out how to make a blank form. It involves screen captures and image editing software.
