G5 Scan Conventional Help
Stpirre
Please excuse my ignorance, I’m new and learning from YouTube.
I have all my conventional channels programmed and set, how Do I set the G5 to constantly scan through the channels? They are all in the 800mhz range.
I have the zone set and the top nob will go through the list if I turn it.
in the software, I added all the channels together.
K9KLC
Southwest, IL
You can scan up to 16 conventional frequencies. Each needs its own knob position. Use another knob position and set that to normal scan and select the ones you want from the list that will come up.
Stpirre
I’m very confused, I’ll attach what I have. Thank you.
Pick a spot where you want the Zone/Knob for scanning, click on it, set it up like the screenshot in post #3, choosing the 16 frequencies you want to scan.
Please, keep in mind the G-series pagers are not scanners, they don't scan as fast and miss traffic at times because they weren't designed with scanning as a key function. It is like using a Baofeng radio as a scanner, they work but not as good as a scanner would.
