G5 two tone programming help
kmh603
#1
I just received my G5 Unication Voice pager. I can not seem to get the pager to trip on a two tone page. I can listen to our Fire Department, but when our station gets a two tone page, my G5 does not trip? I have called unication tech support, all i get is a recorded message- i leave a message- and i never get a phone call back? I have emailed david@unication.com and receive no replies? So i am here asking for some Fire help! Can i send my pps file to someone who can look at it and tell me where i went wrong? My FD is on VHF, Our Ambulance service is on 800mhz. I need both checked out. Email me if you are willing to help. I will send you my exported pps file to look at.
Thank You
hawkredtail@protonmail.com
HRN
#2
Thank You
Who is your dealer? They are your first contact and should be able to help you out.
Sent from my SM-N920V using Tapatalk
Dallas, TX
#4
David is a pretty busy guy and often travels. So he may not be able to help at a moments notice. You dont mention how long ago it was you emailed him or called.
As HRN mentioned, if this is for a department and/or department issued support should come from them.
If you purchased out right again that dealer should help.
Then forums and manufacturers come next.
Do you have the correct tone info?
Are tones sent on VHF only? 800 only, both?
Theres a lot of info missing that we need to try to help you.
troymail
Silent Key
#6
Thank You
I was never able to get 2-tone over P25 working on the system in my area... I have been using conventional 2-tone however.
The conventional 2-tone is pretty straight forward - from what I recall, 2-tone over P25 is much more complicated to set up....
David posted some info on 2-tone setup back in September -- look starting here.
kmh603
#8
VHF Hi is analog frequency 151 MHz and the 800 MHz is P25 Phase 1 trunking. I will check out troymail post.
Thank You
troymail
Silent Key
#9
Thank You
The 2-tone over P25 info is in this post... I can't help much more with that as it didn't work for me (even though I'm told it was configured properly at the time).
I do have "regular" 2-tone working - was pretty easy. If you are still having issues, I can take a look at your config ....
kmh603
#11
Just for information on those following this thread. Troymail was able to fix everything! He even built me a new load with talkgroups and Frequencies. Also Thanks to everyone who emailed me and helped with all boxes and settings. There was tons of things I did not check or add to the menus.
My G5 is at least receiving two tones on the Fire Channel and all the other options Troymail added
THANK YOU :>)
Hawkredtail
