G5 VHF Conventional Scanning
PVPD730
I was finally able to get my hands on a G5. Trying to program this beast has been quite the challenge. P25 trunked stuff is pretty straight forward, however, the conventional VHF programming not so much.
Two questions with regards to the analog conventional frequencies:
1) When attempting to set up a knob position as a "scan list" for everyday monitoring (similar to a scanner), would I select "Normal Scan", "Silent Scan", or "Priority Scan"? The three options presented are a bit confusing. All I want to do is set up one knob that scans 4 or 5 different frequencies and monitor them in a particular order (similar to what the G4 does with trunked talkgroups).
2) As far as automatic two-tone decoding goes, does the G5 even have that capability? For instance, if I don't know what the "A-tone" or "B-Tone" are would the G5 be able to tell me that information?
Hope that all makes sense...
Edit: Found the G5 programming white papers on the Unication Website, so a majority of my questions have been answered. Here's the link in case anyone else finds themselves in a jam: https://www.dropbox.com/s/4m1ip2rlgd0fkt2/Unication G5 White Papers 2016.pdf?dl=0
ffexpCP
wizard of odd
Michigan
Use normal scan. Silent scan is used to monitor for tones silently on multiple channels. I have not used priority scan, but it shows: Selects a priority channel from the Scan List. When the pager is actively scanning a Scan List, 50% of the scans are targeted at the Priority Channel.
The pager cannot display / decode unknown tones.
PVPD730
Appreciate the info. Perhaps I'll play around with the priority scan at some point, but for now it will be programmed in normal mode.
PVPD730
I'm curious to learn how you've programmed conventional channels -- I've got several including P25 programmed but I'm really looking for a simpler way to do so....
Here's what I've done personally:
Navigate to Step #2 in the PPS software. I add all conventional frequencies that are to be programmed.
From there, I add all desired trunked talkgroups in Step 4.
Last (in step 5) I set up the knob positions.
Based on the agencies in my area, I've mixed both trunked talkgroups and conventional frequencies into certain zones. For example: under Zone 71, I've put the analog conventional fire paging frequency in knob position 1. Subsequent knob positions are trunked groups which carry ops, fire tac, etc. All positions that were programmed with VHF conventional frequencies use "Monitor Mode". CTCSS/DCS options are also available if you select the "Monitor Mode". Alert Mode is always selected as "silent" (as a matter of personal preference).
As far as the scan feature goes, I typically set that up under knob position 8 using normal scan. Everything programmed in positions 1-7 gets placed in the list.
My advice: play around with the programming for a bit. Figure out what works best for your programming needs and go with that when it comes time to build out your zones.
troymail
Silent Key
Thanks for the response -- yes, my recommendations to everyone is always to play and experiment as well.... I started even before I got my G4 and am still finding new things a month after receiving it.
I may have in my head mixed some of your original post words that lead to my post/question. More specifically, I am looking for input from others who have programmed P25 conventional channels. For my programming, it seems I have to
(a) add the conventional frequenc(ies) in Step 2
(b) create (one time) a P25 Conventional Protocol (in Step 3)
(c) add at least one conventional P25 talkgroup of "1" (in Step 4),
(d) create a zone/knob position set to "Monitor Mode" for each P25 conventional frequency (in Step 5)
(e) create a second zone/knob position to P25 conventional scan over one or more of the frequencies programmed above (also in Step 5)
Seems like we should not need this many steps... and I just haven't found it yet.
Sometimes the (easier) solution is there and you just can't see it...still looking...
