G5 VHF Randomly Rebooting
ancker
I have a G5 VHF on the latest firmware (2.0.2).
Recently, it will randomly "reboot". I say reboot because it'll be on my hip and it'll just call out the voice for "Fire Dispatch" that I have programmed on that knob position. It's been on this firmware since it was released and worked fine for months until this started happening.
I works perfectly fine otherwise, except it did it once in the middle of a page, so I missed what the call was.
Has anyone seen this before? Could it just be the battery needs to be replaced?
From past posts or reports on this problem it often times has turned out to be battery related, you might try removing the battery and cleaning the contacts then ensure it is properly reinstalled, otherwise a new battery might be needed.
ancker
Thanks. I have a new battery on the way from Ray's. It's probably about time anyway.
I'll try cleaning and reseating it as well.
K9KLC
Southwest, IL
I find if I drop mine or it's on my belt and takes a shake or bump it does it. Never thought much about it. I think I'll give my contacts a check. The pagers are both older but the batteries are less than 6 months. They both have done it.
ffexpCP
wizard of odd
Michigan
If it continues after ruling out a battery issues, I'd contact support.
I've experienced this behavior too. I was able to send support a log and they were able to identify the firmware issue.
