Galaxy DX-33HML???
CatfishKirk
Central, Alabama
I was recently given a Galaxy DX-33HML radio. It did not have a power cord so I researched the name and read that this radio is not a cb as I was told but a 10 meter radio. Then I read another thing that said it was a cb radio. I would like to know what this radio is and if it truly is a 10 meter radio what that is as well. Thanks
nonperson
GA
It's an "export" 10 meter radio. However many of them are "converted to operate on the 11 meter, CB band. The FCC rules says it's an unauthorized radio to use if it can operate on the CB band.
If you use it make sure it is on (CB) frequency, it doesn't interfere with other radio devices and don't transmit on the HAM frequencies etc. Other wise some HAM operator or other user(s) will report you.
The only time I've heard of these types of radios being a real issue or being reported is when they do the above mentioned things. So use at your own risk. I'm sure someone will be along shortly to point out the penalties etc so I will not steal their thunder. :D
nonperson
GA
Based on my understanding of the rules the answer would be no. However it is done a lot. Just don't get caught. :D
If it was me I would hold on to it but if you want to sell it try a truck stop. Good luck!
Central AL
I know these radios are usually intended to be used as CB's but are sold as 10 meter radios.
Do these radios actually work well if they're used on 10 meters? I know they seem to work well on CB but I just wonder if they actually work on 10m like they're advertised to or is it just a marketing gimmick?
K9WG
Greenfield, Indiana USA
bob-the-scanner-man
These 'export' 10-meter radios are nothing more then a attempt to skirt the FCC rules and for most serious Hams are not useable. Most do not have sideband or have limited frequency range on 10-meters. I never understood why an Amateur Radio operator would need an 'echo' feature. For the price of one of these '10-meter' transceivers you can get a nice used rig that was engineered for Ham radio.
Just my not so humble opinion.
btw: I purchased a Radio Shack HTX-10 right when RS was getting out of the Ham market. I was afraid it would be a glorified CB radio but found it to be a great little rig and worked many countries both base and mobile.
Central AL
K9WG, that's about what I figured. I'm both an amatuer operator and a CB operator and a 10m "export radio" doesn't really appeal to me for either.
You're right that if you want a 10m radio you can get a better radio with better features for the same price.
Also, I don't really see the appeal of these as CB radios. Aside from the legality I just can't see any features that are really appealing. Most of these export radios are AM and FM, but not SSB which is stupid. If I'm going to spend that much money on a radio I'd expect it to have both AM and SSB. What use is FM on 11m?
K9WG
I think the appeal of these 'CB' radios is the slightly higher power and the ability to tune out of band. I also get a kick out of the outrageously big CB antennas I see on cars/trucks. I guess if you have a BIG coil you can modulate better....
nonperson
GA
I use to wander about those "big coil" antennas. I have fairly recently learned that those coils do serve a purpose. I can't remember exactly how they help but it's got nothing to do with modulation. :) I think it was to do with tuning or making the short antennas more broad banded? However I bet some just have them for the "cool" factor. I'm sticking with the 102" whip.
So this radio would not be good to use as a base station cb nor would it be worth my time in getting ham licensed to operate it.
I wouldn't say that....
Make sure it's on frequency and doesn't "bleed" over or interfere with others. If you were to get your HAM license you could use it on the HAM frequencies (it covers) but you may be limited with what you can do as a HAM operator with that radio.
I use to sweat over the FCC rules. But after reading some of the enforcement letters posted on forums like this, it appears as long as your equipment doesn't interfere with other services and stays on frequency, the FCC would probably never know about it. :)
If I was to get an export 10 meter radio I would get one of the RCI radios like these: :D
CBRadioMagazine.com - RCI-2970N2 10 Meter AM/FM/SSB Export Radio Review
CBRadioMagazine.com - RCI-2950DX 10 Meter AM/FM/SSB Export Radio Review
CBRadioMagazine.com - RCI-2980 AM/SSB Video Review CB Review
:D
Unfortunately I can't afford one right now. :(
