Galaxy Saturn, the chassis is hot (current).
Metalhead396
Creedmoor, NC
I just bought a used Eagle 2000 which is the same as a Saturn. The radio seems to operate fine but the chassis has at least 25 volts AC running through it at all times (on or off). I have looked everything over but nothing jumps out at me. I could use some suggestions please.
prcguy
There would be around 25 volts AC right off the power transformer before the rectifier bridge and sometimes there will be a bypass capacitor from the transformer secondary to chassis. If that shorts it can put some AC on the chassis. There can also be a bypass cap off the AC input cap to chassis that can cause a similar situation.
prcguy
The power transformer should be obvious and the bridge rectifier is the little square thing with four connections below it in the picture. I would one an ohmmeter and check for any resistance from the bridge rectifier to the chassis and if it’s low like less than 100 ohms I would find out why. Same with both prongs of the power cord to chassis. I would also look for any wires or components that may have been bent over and are now touching the chassis or other components in the power supply area.
