Gas leak in Johnstown w/reverse 911 going out
aprswatcher
Lewistown, Montana
Johnstown/Milliken units on scene of gas smell in north Johnstown WCR 17 & WCR 48 1/2.
High levels of gas in area. Asking Weld dispatch for reverse 911 calls to houses on Blake & Conrad streets
(This is a pretty small subdivision) Excel gas just arrived on scene.
O/F CO DTRS Weld Co Fire disp & Weld Co FG17
Updates as I hear them.
73, Rex
aprswatcher
Lewistown, Montana
Command allowing residents back in homes. Canceling any remaining reverse 911 calls.
Releasing units.
73, Rex
