GD-55 plus programming software
wolfhound89
Fort Worth, Texas
Recently I picked up a GD-55 plus to get into DMR and check it out.
I have been trying to work with the software that came from the radio and it is a little clunky. I also do not believe that it can import any other file types or CSV files. It was recommended to try contact manager software however I run into the issue that I cannot export it into the file type (pgm) that the GD-55 plus uses.
It has been said that I have to start with a blank slate and start the programming myself.
Thank you.
SCMajorInci
Spokane County, WA
Ive been working with the software myself. Everything has to be hand coded into the software. If you would like some help let me know. I can make a file and send it to you.
wolfhound89
Fort Worth, Texas
Thank you very much. That would be greatly appreciated.
I am in the Dallas / Fort Worth area and while I believe that I have found the information for local repeaters it would be a good starting point to see what you have for comparison.
I will send you a DM with my email address.
Thank you again.
