GE / Ericsson / MA-Com hand-portable antenna connections
mitaux8030
Silent Key
Home
Hi all,
I've had a bit of trouble determining which of the hand-portable radio antenna connections (not the UDC antenna connection) are the same on the GE / Ericsson / MA-Com family.
I think the MPA, MRK and LPE all use the same connection? Any more cross-compatibles to add to the list?
Thanks - Jason
ElroyJetson
The M-PA's connector is the same as that of the M-PD. It is not the same as the others mentioned.
M-RK, LPE/Prism, Jaguar 700, 7100IP, 7200, and 5100 series radios all use a common UDC connector,
but connector shells are not fully interchangeable between them. Some accessories will fit on one
radio but not on another. An example would be speaker-mics for the Jaguar/5100/7100 series,
using the quarter turn fastener to secure them to the radio. They won't fit on an LPE or M-RK
unless you modify the connector shell.
Elroy
mitaux8030
Silent Key
Home
thanks for that - I was actually asking about the actual antenna that is screwed into the top of the portables, not the UDC connection. Just wondering what flexible antennae are interchangable between which models...?
I think I've got information that shows the MPA, MTL, MRK, KPC, 500P and LPE all use one common flexible antenna thread / connection, but just wanted to confirm that...
