Muxlow
Super Secret
I just got a TQ 3310 rib to program my MDX radio with. I made a cable for the radio to the rib. All is good n such.. Go to connect the DB25 cable that came with the rib to the computer... and nothing fits.
The DB25 MALE end is connected to the rib's COMPUTER side that has a DB25 FEMALE connector.
The other end of the cable is a DB25 female. Only port on the computer is the "printer port" and that is also a female connector. Do i need to buy a female to male converter or a DB25 female to DB9 converter and use the standard com port rather then the "printer port"?
Never used a real GE rib. Always used ribless cables so im a little confused on how to connect this.
Also no power supply was with it so do i just use a 7.5v supply or a 12volt?
Says 7.5-15 VDC
Says 7.5-15 VDC
