GE Superbase - no modulation...ideas anyone?
Retroradio
Ontario
I just picked up a very nice GE Superbase.
- receives well all channels both AM and SSB.
- is transmitting a carrier ( used an external meter as well as checked with the radio meter )
- Tried the original mic - suspected it was non servicable so I wired up a D-104.
NO Modulation on either microphone.
Anyone have any idea on if this was a common problem and were to start looking?
Dawn
Pinecrest,Fl
Does it transmit in SSB?
Hooking up a speaker to the PA, do you get amplifed audio?
First steps to try.
Retroradio
Ontario
Dawn,
With no modulation it is not tx in SSB....Will double check.
I forgot to try the PA. I will do that tommorow and post the results.
Thanks for the nudge.....lol
Retro
Retroradio
Ontario
Simple fix after all. There was no modulation when set to PA. Therefore I played with the Speech compression switch and if it was held just right and I stood on one foot....( you get the picture....lol)
Ta-Da modulation.
I sprayed the switch with a cleaner/lubricat and have great modulation now with the stock microphone. The D-104 just feeds back with no modulation. I used the wiring diagram thats online for the 6 wire mic. I have verifed the wiring so I am going to try a Turner +2 next and see. I really dont like stock mics.....
Overall this is a very nice radio cosmetically and seems so far to be performing well. I am going to do a comparison test between this and a uniden 980SSB just to see how it stands up.
Cheers!
Retro
Dawn
Pinecrest,Fl
Glad to hear you got somewhere. That's been the case of most older radios that have set up I've found. Particularly the NC audio return contacts on the PA jack. A tiny dab of deoxit D-10 to clean off the tarnish on contacts and a little exercise takes care of the problem. If you every run into the problem with a relay or make/break leaf spring contacts like in a mic. A drop or two on the end of a dollar bill is usually good enough without having to resort to a burnishing tool that affects the plating.
Retroradio
Ontario
Thanks for the tip. Oddly coincidental as I have a D-104 G and a Turner +2 in pieces right now in front of me.... D-104 was an internet buy and I just discovered it looks to rewired and looks to have the 2 end lugs on the wiiring lug plate snipped off. ( Doent match the astatic guide.)
The Turner just needs to be wired up for the Superbase. I am digging through the radio archives for this stuff! I am trying to find the best combination for this radio.
