General information on a Quantar UHF Repeater
dmason04
I support our police.
BEE00-152-1-5
Howdy,
I was looking online and found a used Motorola Quantar repeater in UHF that I'm interested in purchasing. I wanted to see if the RR community knows the answers to the following questions:
Am I allowed to operate the repeater under a basic HAM tech license?
Will the repeater function as a TRS?
What sort of external antenna equipment will I need to mount on my house?
Thanks,
David
cpg178
If your trying to make a trunked ham system your gonna need alot more than just 1 repeater
littona
Super Freq
Council Bluffs, IA
Yes, but you should do frequency coordination with the respective group that handles your area. Is it required? No. But it's a good idea.
You need to ensure that you're staying within the frequency and power authorizations of your license.
Not sure what you mean by TRS... a Quantar is a repeater. It receives on one frequency and transmits on another simultaneously.
You'll need a UHF duplexer and an appropriate antenna.
Make sure you can get the Quantar programming software. You need a serial port to program it, but may be able to get away with a decent USB to serial port adapter. You can make the programming cable if you can get the parts. The programming cable for these machines is just a regular null-modem serial cable, nothing fancy. https://en.wikipedia.org/wiki/Null_modem
prcguy
The Quantar is without question, the finest affordable repeater you can buy right now. Its replacement is the GTR8000 but those are running around $7k and up used and Quantars dip down to around $600 for UHF occasionally. In the US you can own and operate a repeater with a Tech class amateur license but you may need to seek frequency coordination from your local ham coordinating group.
You will need a good duplexer so plan on spending about $250 on up used and the antenna is key to coverage so don't skimp there. I would not go for anything less than 6dBd omni gain and a commercial quality antenna not a hamster brand. Many ham antennas have internal wire element connections using chrome or other plated parts that can cause Passive Intermodulation when lit up with RF. It doesn't affect a regular push to talk radio but can raise the noise floor in a full duplex system.
The Quantar is very easy to program and align and once aligned it can be programmed across a few MHz without retuning. Programming software is available on Ebay and a programming cable is a simple 9 pin serial null modem cable. The 110 watt UHF version will run 110 watts key down forever but many people back the power down to about 85 watts or so.
What area are you in? If its So Cal I can help with technical info.
