General question
hotsavannahs
San Antonio
I want to monitor the uvalde county sheriffs office and police dispatch. Located in uvalde county Texas. They are on a Motorola radio system. I have downloaded the uvalde county frequencies into my uniden 325p2 but do not hear any broadcasting. Is this system encrypted?
UPMan
In Memoriam
Arlington, TX
They are not on a Motorola system. They are on an APCO P25 Phase I system. The channels they use on that system are not encrypted, according to the database. Note that questions like this are best asked in the appropriate state forum.
rwier
Phoenix, AZ
" ... I have downloaded the uvalde county frequencies into my uniden 325p2 ... "
To explain that statement in enough detail to get any REAL assitance from an actual knowledgable RR member you might have to type 1000 words. Let's start by keeping it simple, step-by-step.
Based upon the RR WIKI information (https://wiki.radioreference.com/index.php/Uniden_DMA_Software_Support), your BCD325P2 offers 4 different methods of "programming". Three of these methods involve software. The three software options are shown as ARC-XT, FreeScan, and ProScan. The fourth method (not shown) is the dreaded manual method (lol).
Assuming (lol) that your particular scanner can actually properly receive Uvalde County "frequencies", the best assistance will probably come from someone who has the same scanner, and uses the same "programming" method (of the four options).
Since RR claims to have " ... hundreds of thousands of members ... " (https://www.radioreference.com/apps/about/), there is good chance that several RR Members would fit this situation.
So, step #1: Which of the four "programming" methods did you use in your "programming" attempt?
Project25_MASTR
Millennial Graying OBT Guy
Texas
Though not the SmartNet P16 System which is typically defined by the term “Motorola System” it is in fact a Motorola System…just a Motorola Astro 25 system. And while it does operate according to the APCO Project 25 standards it also has some proprietary Motorola features which are active. Have to be careful about that.
rattlerbb01
TX/LA Database Admin
Boerne, Texas
OP,
I just drove through last night. The SO and Uvalde PD are on https://www.radioreference.com/apps/db/?sid=2
When you program this system, you will want not only the Uvalde tower but Utopia as well as Leakey so you don't miss anything as you move around the hilly terrain. Uvalde PD is particularly active and the SO is a little more laid back.
There are also several Fire and EMS repeaters that are still conventional VHF analog. You can find them on the county page.
