Liverdog
- Joined
- Dec 19, 2002
- Messages
- 308
[perhaps we can make the answer to this a sticky]
Rick (or other knowledgeable member):
In general, what needs to be programmed into an scanner that is being controlled on a COM port by UniTrunker? I'm not concerned about the RS232 signalling and COM port numbers, I'm asking about the scanner programming.
In my case, I am using a Uniden BC250d, but how do I setup the memory channels or search ranges for use by UniTrunker so that as a frequency becomes active, UniTrunker commands the scanner to that frequency?
I spent about 30 mins searching the RR database for the answer but I didn't see anything.
Thanks in advance
Thanks in advance
