Genoa Peak Fire
Northern Nevada/Sierra Front
Well these wet storms still sparked a fire in heavy timber that burned all through the night, and very visable from both Carson and Douglas Counties. The Genoa Peak Fire is burning 10+ acres in heavy timber above the town of genoa. The Feds lets it burn all night without personel onscene. Its a full walk in show.
Command 169.8750 Humblodt-Toiyabe Net
Air to Ground 165.650
123.975 Tanker Base Contact
It wasnt to bad of an airshow, I sat on Genoa Lane watching the show, snapped a couple pictures while i was there too.
Frequencies
Command 169.8750 HTF Net
Tacticals
White Fire-1 154.280
NIFC Tac-2 168.200
Red Net-1 159.345
Red net-2 158.8650
Air Nets
A/G Pri 165.650
A/A Pri 120.975
A/A Victor 122.750
BLM Air Net 168.550
Flight Follow 168.650
