George County Sheriff Office Frequency
I will try to contribute instead of cause a problem this time.
I am located in the NE part of Jackson County - Hurley
I have an active frequency that appears to be George County Dispatch and/or SO opereations. 156.2100.
I am still trying to locate the frequencies for MS HWP. I have several but no traffic. One that seems active but appears to be data only. 866.0125
Thanks for any help
hm
Thanks for the info. 156.2175 does not appear to work. I had most of the HWP Freqs but few hits
thanks again
hm
INDY72
Indianapolis, IN
If you have say a PRO-97 or the like, then load the 156.2175 and itll pick up nicely... What type of scanner are you running?
INDY72
Indianapolis, IN
Also, on MHP, unless you have a huge antenna on a tower, most likely all youll hear is dispatch.... Untill the MWIN 700 gets set up.
I have the BC796D and use the Radio Shack $30.00 antena mounted on a 20 ft mast
INDY72
Indianapolis, IN
You should have no trouble at all with that narrowband freq GCSO is using, but youll still only here MHP mobiles that are close to you, and the mobile extenders in the cars, if they are close to ya,... But dispatch should be clear as a bell.
Mick said:
Hello. Your 156.21 is a close match to the 156.2175 here at RR's database for George County:
http://www.radioreference.com/modules.php?name=RR&ctid=1416
Here at RR there is a listing for the Mississippi Highway Safety Patrol (MHP):
http://www.radioreference.com/modules.php?name=RR&aid=762
I tried locking out 156.21 and replaced it with 156.1275. Listening and logging for serveral hours I never got a hit. I unlocked the 156.21 and pickup a lot of hits both for George County Sheriff and also the Gulf Shores, Al Police department or may be the Baldwin County Sheriff Department as I have also copied dispatches to Daphnee Al as well.
I am picking up the HWP now. I added the fixed Repeater frequencies listed in another message. One that is supposed to be for this area, 453.0000 has a lot of traffic but its for the Crew/Supply boats serviceing the offshore rigs and Chevron.
Thanks for your help
hm
INDY72
Indianapolis, IN
For total info on MHP check out the STICKY on MHP and all the listings in the DB here. All the info is current and up to date. :)
nexus
Mississippi
My info on George County (Accurate as of June 2005)
Sheriff Dispatch: 156.2175 mHz (Repeater)
County EMS: 151.0400 mHz
Lucedale PD Ch 1: 159.1500 mHz (Repeater) *note they use southernlinc too*
Lucedale PD Ch 2: 155.6250 mHz
Lucedale FD Ch 1: 154.4450 mHz
Singing River Electric: 153.4250 mHz (APCO25)
nexus
Mississippi
hm
That Chevron Bullcrap is NEW! I've started noticing them talk on 453.0000 starting back about 2 months ago. Before that the only people I ever heard on it was Biloxi (Troop K dispatch). But it wasn't very often. I hear the units on 458.0000 all of the time when driving down I-10.
INDY72
Indianapolis, IN
Hmmm possibly a slight offset freq that our scanners get on 453.0???? Possibility of actual freq on sayyy 452.9875?? or in that range?? Is it showing a PL/DPL????
nexus
Mississippi
I'm using a Yaesu FT-8900R Transceiver to pick it up, and it has to be on frequency because I'm hearing them from Biloxi, and they're 29 miles away from me in Pascagoula. So if they were on anything other than 453.0000 mHz I wouldn't hear it.
Unknown on the PL, I didn't scan for one. I have 453.0000 and 458.0000 loaded in my radio and scan both, and noticed traffic that wasn't MHP on 453.0000 a couple of months ago. I identified it as being in or near the Chevron Refinery. Also I believe it's a repeater, it sounds like a repeater. But if they were on say 452.9875 I don't think I'd hear it from 30 miles away mobile. My transceiver is too selective.
