Curious what helpful resources there are online to get me started in the hobby. I have a BC125AT and will grab a 5/8 Smiley.
I think something like OpenRailMap or other websites with information on where to find which companies travel which lines, etc.What are you specifically looking for help with?
One of the best things I ever did was get an external antenna on my vehicle with a permanent NMO mount, seriously will increase your reception when you are in your vehicle.
I would also suggest programming in all 97 AAR channels into your scanner, this can be useful in areas you are unfamiliar with. This just happened to me last Saturday, I was in a town I've only been in a few times which has a very low traffic KCS line going through it, and I've never been quite sure what channel they use in that area. I turned banks 1 and 2 on in my BC125AT which have the 97 AAR channels in them, and not long after I hear a train crew tone up the dispatcher on a channel that I would not have otherwise been monitoring and I got a shot of a westbound in good lighting.
Also program in the EOT/HOT/DPU channels into a bank, these can alert you if there is a train nearby, you will hear short data chirps. Make sure you use the alpha tags to name each frequency, DPU transmissions are at a higher wattage than HOT or EOT so they obviously will travel farther, I've picked them up as far as 20 miles from any railroad line before although that is not common, usually its 5-10 at most, but HOT and EOT are usually just a few miles. If you get a hit on EOT or HOT a train is usually pretty close. Keep those in their own bank because at times you WILL want to turn that off, especially if your in a town that has a yard or several trains, it can be enough to drive you crazy.
To be faaaiiirrr... there's only 90 channels in the US technically.. AAR 007 thru AAR 097. But yes, I would program all 90 in, but lock all but the ones you need out. That way you can have them there if you go somewhere where you might need them. Having 90 channels on scan especially on a cheaper handheld can yield poor results.
Mike
Just to add to this, if you do program all the AAR channels, program them so the scanner channel matches the AAR channel. Railroads refer to the channel numbers when changing the radio channels. You could hear them refer to a four digit number Ex. 3232 or ????, this is both the receive and transmit for their radios. If the first two are the same as the last two, you just need to tune the first two numbers.I would also suggest programming in all 97 AAR channels into your scanner, this can be useful in areas you are unfamiliar with. This just happened to me last Saturday, I was in a town I've only been in a few times which has a very low traffic KCS line going through it, and I've never been quite sure what channel they use in that area. I turned banks 1 and 2 on in my BC125AT which have the 97 AAR channels in them, and not long after I hear a train crew tone up the dispatcher on a channel that I would not have otherwise been monitoring and I got a shot of a westbound in good lighting.
