GEWIN/Cobb custom frequency table?
FPO703
Planet Earth
If the system is 800 MHz, you shouldn't need any Custom tables. You shouldn't need one for 700 MHz, either, for those scanners that will trunk track on 700 MHz
b7spectra
EMS Dispatcher
Cobb County, GA
As above, it just scans normally (in digital mode) as any other type II system. No special programming needed.
I should have an updated list coming out on the GEWIN Cobb County portion in a few days of what talkgroups are active (don't ask how I get this info!).
mikey60
Oakland County Michigan
Casey said:
There is a new system entry for the COBB system on the GEWIN trunk page. Could the poster of the custom table on the GEWIN page help fill us in on this? Does this apply just to Pro-96 users? I'm using the Uniden 396t and it trunks perfect without, thanks...
http://radioreference.com/modules.php?name=TRSDB&sid=4487
I'm not sure where those offsets came from, but they are definately invalid for 9600bps systems. As mentioned, you don't need to set a custom table for 800mhz systems. The default tables will work just fine.
Mike
b7spectra
EMS Dispatcher
Cobb County, GA
I'm running Pro-96Comm on my computer hooked up to my Pro-96 and am receiving the following:
System ID 17D
Tower ID 101 (T0101)
WACN BEE00
Tower Description Kennesaw Mountain
System Description Cobb County P25
Capabilities Data, Voice, Registration
Call Sign Unknown
Tower Status Connected
ID Base Spacing TX Offset A/C BW
00 851.00625 0.00625 -45.0000 c 0.00625
01 762.00625 0.00625 30.0000 c 0.00625
Casey
East Cobb County GA
Someone may want to update the news entry because those are also the same base and offsets for the State-owned GEWIN control channel also, not just Cobb as the news entry seems to suggest.
Casey
East Cobb County GA
Looks like it's now taken care of :)
