Throw it in the trash and get another onei got a couple gm300's for cheap, i programmed 446.000 into channel 1, but it is actually transmitting centered on 445.992
question
1. is this fixable ? IE can we adjust to actually be on frequency?
Nonsense. VCO off frequency and a common issue with these radios.This is beyond a VCO alignment, Looks like a bad memory chip.
Fixable but is it worth it.
That is true but no reference VCO will go 1Mhz off frequency.Nonsense. VCO off frequency and a common issue with these radios.
EEPROM failures result in radio not booting up, it does a checksum validation every time you turn the radio on. If it boots up with a positive beep, it's good.That is true but no reference VCO will go 1Mhz off frequency.
A couple Khz is stretching it
Very obvious the PLL data is not right.
TX mixer switch diode gone bad might do it.
Yup. I asked what he used to verify its off but no reply. Unless its a calibrated meter or monitor I wouldn't remotely worry about it. I have watched folks use frequency counters tell me my APX is off frequency that just came off the auto tune.445.992 from 446.00 is not 1mhz off (its true I was lousy in math in School but I subtracted 5 times to chevk myself) and should easily be tweaked on with RSS as mentioned.
How do you know he is 18ppm off without knowing what he used to check it. His frequency listed is not part 90.At around 8 kHz off, you'll start to have PL decode issues with a normal radio. It's also not legal in the case of Part 90, you're allowed 2.5 ppm in that range, and he's 18 ppm off.
8 kHz is way off. That's more than 1 max deviation. If a reasonably modern non-Baofeng radio that hits the local repeaters fine says it's 8 kHz off, then I trust it, particularly with the known issues with this radio.How do you know he is 18ppm off without knowing what he used to check it. His frequency listed is not part 90.
You will have PL and distortion issues way before being 8KHz off, more like about 2KHz off will start sounding distorted on a WB channel and 5KHz off is usually a fuzzy sounding mess.8 kHz is way off. That's more than 1 max deviation. If a reasonably modern non-Baofeng radio that hits the local repeaters fine says it's 8 kHz off, then I trust it, particularly with the known issues with this radio.
If the OP was reporting they were 1 kHz off, I'd agree with you and say to use a calibrated service monitor or frequency counter before tweaking anything, but 8 kHz is at the point where you get PL issues and audio noise.
MTS2000des is a radio GOD!. Whatever he says is what you should take as the answer. Learned quite a bit from his various posts.That is true but no reference VCO will go 1Mhz off frequency.
