Gmrs/Frs antenna
sandiegosand
San Diego, CA
Me and my buddy use radios to communicate frequently, but our houses are just barely out of range of each other (we just get a little static). I am a technichly inclined do-it-yourselfer, and i'm thinking about running a wire up a tall tree in my yard, and wrapping the other end around the antenna of my radio. Do you know if this would help, and what wire would be the best type to use?
gewecke
Illinois
Google " Passive uhf on glass antennas"
That's your easy solution. ;)
73,
n9zas
gewecke
Illinois
No. Passive on glass antennas have no cable or direct connection attached but radiate the rf from your talkie when it's nearfield to the antenna. ;)
73,
n9zas
D
DaveNF2G
Guest
That would be a great invitation to lightning and other static discharges to come right to your radio.
gewecke
Illinois
For the op, here's some reading for a solution to what you want to do. As others have said, wrapping wire around your antenna won't work.
But this might,
Patent US6690330 - Glass-mounted coupler and passive glass-mounted antenna for satellite radio ... - Google Patents
It looks like this (but the coiled antenna will be only 5" long).
http://www.google.com/patents/EP0458592A2?cl=en
I would suggest modifying a cellular on glass passive antenna by unscrewing the antenna that comes with it and cutting it to about 5" then screw it back on to the mount and attach it to the highest single pane window you have access to. Keep your talkie within three feet of the inside of the mount where the 2 horizontal antennas stick out.
If both of you have one of these, it should be some improvement. ;)
73,
n9zas
dksac2
Idaho
Get on the roof of your house. Height is your best friend when using GMRS bubble pack radios. Better yet, buy a pair of GMRS radios with removable antennas and more power, then you can put an antenna as high as 20' taller than your house as long as it's connected to your house.
When you get tired of trying to reach friends with GMRS, go get your Technician Ham License, then you can really talk, especially if there is a repeater or two in the area.
John
gewecke
Illinois
John
Amateur radio might be overkill if he simply wants to talk to his neighbor. :D
73,
n9zas
bill4long
Indianapolis
MURS could be a good solution. No license. 2 watts. External antennas allowed. (Up to 60 feet high!) You could put up a small antenna outside and be full copy or close to it. You could get two Wouxun radios for MURS, about $100 each. (Don't use the ones for Amateur radio since they are not type accepted for MURS.) Comes with Lithium Ion battery and quick charger. Of course, the radios are a bit more expensive than FRS bubble pack crapola. But they will be good radios. You probably won't even need an external antenna if you can already "almost hear each other" with the FRS junk, which at best put our 500 milliwatts and on 462 Mhz, which is more sketchy than 151/154 Mhz where MURS resides.
Wouxun are not type accepted for MURS either........
The ones made for ham radio are not. The ones that are made specifically for Land Mobile are type accepted.
The ones for Ham and part 90 are one in the same,the only part 95 Wouxun makes is branded Powerworx or a different spelling there of but only for the UHF GMRS band,
KB7MIB
Peoria, AZ.
Wirelessly posted (Mozilla/5.0 (X11; Linux i686; U; en-US) Gecko/20081217 Vision-Browser/8.1 301x200 LG VN530)
What Wouxun model number(s) are certified under Part 95 for MURS?
I've seen MURS radios by Dakota Alert and Intercomsonline. I have a Dakota Alert HT, I haven't taken more than a cursory glance at Intercomsonline.
