So I was talking with a ham about GMRS today and he was saying how GMRS is too limited because you can only run 5 watts ERP. I was thinking to myself that GMRS is allowed 50 watts unless you are operating on one of the few interstitial channels shared with FRS, then the 5 watt ERP rule comes into effect.
So, I went home and looked at the GMRS page on the FCC's website, and under the heading of Operating a General Mobile Radio service (GMRS) system, they say "A GMRS system consists of station operators, a mobile station (often comprised of several mobile units) and sometimes one or more land stations. A small base station is one that has an antenna no more than 20 feet above the ground or above the tree on which it is mounted and transmits with no more than 5 watts ERP."
Ok, that's fine but what is the difference between a small base station, and any other type of GMRS station? Rule 95.135 clearly states a maximum of 50 wattsis allowed, and then defines 3 more power limits:
I'm so confused
Thanks for any help!
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]95.135 Transmitter power limits. [/FONT]
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](a) No station may transmit with more than 50 watts output power. [/FONT]
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](b) [Reserved.] [/FONT]
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](c) A small control station at a point north of Line A or east of Line C must transmit with no more than 5 watts ERP. [/FONT]
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](d) A fixed station must transmit with no more than 15 watts output power. [/FONT]
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](e) A small base station must transmit with no more than 5 watts ERP.[/FONT]
So when is a GMRS station allowed 50 watts?Does this mean a home base station can only use 5 watts ERP, or 15 watts PEP, or the full 50 watts?[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif](a) No station may transmit with more than 50 watts output power. [/FONT]
I'm so confused
