Gnu radio gr-dsd plugin how to build or compile it use it?
Kenzi
Hello, my system windows 10, x64.
I installed successfully gnu radio and everything seems okay.
I try to listen some digital speech and founded a plugin called gr-dsd. The link is below.
https://github.com/argilo/gr-dsd
The problem is that install instruction are in Linux or something else.
What do I need to compile gr-dsd the easy way please?
Do I need Cmake, do I need Cygwin64, do I need Git bash or something else?
What does mean Rebuild the module using gr_modtool?? How to do it use it?
I searched also the google but did not find any noob friedly tutorial or set-up.
hamradionl
Why use GNU radio for DSD?
When you have WIN10 there are easy options like install DSDplus or install SDR# + DSDtcp plugin both work 100% and cover most digital modes used.
Kenzi
Hello, the reason is that i am using LimeSDR and the base software for it is gnu radio (one of it) others like SDRsharps are produced manily for different hardwares. And with gnu radio i dont need to use virtual audio cable or other stuff so if i would get it working it would be easier to set up and easier to use.
hamradionl
Aha i understand very nice LimeSDR
For SDR# you dont need VirtualCable anymore
You write author SDR# and ask him very easy and friendly.... put in the driver support LimeSDR hardware or ask author from the lib USB driver.
Kenzi
So your saying that i should ask or find driver that supports DSD+ or DSD on LIMESDR, because SDRsharp works with limesdr i allready have the plugin.
