Golden Eagle III, 2 pin Microphone?
RRR
OFFLINE
USA
I recently received a nice Golden eagle 3 CB, and it takes a 2 pin microphone. Where would I get one at, at a reasonable price? I am not looking for original or super fancy.
Thank you in advance.
prcguy
Many mics will work on the radio, you just need to wire it specifically for that radio. The connector only has two pins but they use it as a three circuit connector by connecting to the shell for ground.
My first choice if I were into Brownings would be an Astatic D104 non amplified or even an amplified should work fine.
prcguy
RRR
OFFLINE
USA
I have an old Astatic D104, does anyone know where I can get a wiring diagram for the CB mic input on the DB so I don't screw it up?
Retroradio
Ontario
Type in Astatic Mic Wiring guide on the net and the 30 page handbook will show up....
Its a great little Reference.
There are lots of wiring guides out there. An idea if you play with radios is to to gather the info , print it and make a reference book. :)
The 2 pin connecctor was used with the Heathkit radios and is a bear to find. On mine I swapped some out on the radio for the more commercially available connectors when I couldnt get the 2 pins.However its a Golden Eagle so.....
