Gp2000
Torun
Hello guys
I have a problem with GP2000.I program it so that PTT ID should be sent when pressed ,but only voice signal is recieved and ID isn't displayed on the radio screen. PTT ID is enabled on the channel and as voice signal is heared I assume it's transmited,but why isn't it displayed ...
would appreciate if anyone could help with it :)
Torun
No exactly PTT ID.
It has... problem is I don't have full manual.... from what I've learned from my manual, I've set PTT ID (8 digit code) in RW meniu, then enabled it on the channel.. there is also an option to send ID upon pressing PTT,after or in both times... I tried all this cases and indeed voice signal is heard according to this option... but only thing I see on the screen is CH 001 ,code doesn't display :/ ...........
strange thing is with Selective call too... AFAIK if you want to send SC you need to push PTT and deal number .I've enabled SC ,but when I press PTT and try to deal number ,nothing displays - again just CH X .
I might think that this is due of my radio station ,but as both radios have this problem I guess is less likely ..............
