GP300 Programming Issue - Invalid Frequency
JB1991
Kings Mountain, NC
Okay, I feel like an idiot, purchased a VHF GP300 portable for a fellow firefighter here. In the process of programming, I failed to realize that the available frequencies are in the 400MHz range, where it needs to be around 130-160 MHz........ Do I need to purchase a new radio or is there something within the Radio OS I can change???? ANY HELP would be greatly appreciated.
Regards,
Jon Beard
KG4INW
Midlothian, VA
Yes, you need to purchase a new one. Changing bands would be too difficult and more cost than getting a proper range radio, if changing it could be done (hardware change, not software change).
62Truck
Ordinary Subscriber
Uranus
and I'd look for a different radio something that is Narrow Band capable..Try looking for a P1225 they use a windows based CPS and they will do narrow band and uses the same accessories as the GP300, except the battery and programming cable.
cmdrwill
So Cali
The GP300 is a great radio, even today. The UHF version covers 438 to 470. The VHF version is 136 to 174 mHz.
There are other ranges in the GP300 model line.
403 - 430
465 - 490
They do not cover some of the new narrow band frequencies.
If we knew the frequencies you need, we can tell you if the radio will support them.
62Truck
Ordinary Subscriber
Uranus
You might want to re-check those band spits cmdrwill on the uhf one. cdmrwill
firefive76
Kansas
Go with this advise. A GP300 isn't narrowband capable. In other words, it will be of no use in a year and a half. If you are looking for a decent cheap handheld, look at the CP200 or CP200XLS.
faxjax
Idaho
Gp300
Hello, Appreciate any help you can give me as well.
Have some Gp300s VHF radios we use when riding in the woods. Want to know if they will be able to be reprogrammed to the new Narrow Band requirements.
We maining use the freq that came in them. It is 154.600
Can anyone tell me if this will be possible?
firefive76
Kansas
GP300's are not capable of narrowband.
trlrdrdave
decatur, al
Some gp300 came narrow band. Must check model number. They were either or you can't specify in programming.
faxjax
Idaho
GP 300 Narrowband
Thank you Firefive76,. I was afraid of that.
and Trlrdrdave I will have to get the model numbers and post them.
Thanks again to both
firefive76
Kansas
