I have 6 GP300 radios to programme, I programmed one and then cloned the codeplug to the others.
On 4 of them the cloning went fine.
On one I got a model number mismatch - it's a P94YPC00D5AA whereas the others are P94YPC00D2AA. The problem is that the Tx frequency can't be set to the value I need as the allowable range is 403.0 to 433.0, I need 449.xxxx. I guess there's no way round this limitation?
On the other the codeplug copied OK, all the data is correct, however the channel selection is wrong. Channels 1-4 are fine. If is is set to Ch5 it will only communicate with the other radios if they are set to Ch1, if Ch6 is selected the others have to be on Ch2, if Ch7 is selected they have to be on Ch3 and if Ch8 is selected they have to be on Ch4. What's going on here?
