BCD536HP: GPS Location
Alexandria, VA
#1
I did a search, and couldn't come up with the answers I was looking for.
Does the 536 take in the GPS location from a device on demand (constant), or does it take it in on set intervals? I ask because on my trial run, it didn't seem to drop/add systems for almost 10 additional miles. Range was set to 0, and I confirmed locations using google earth before and after my trip.
If the 536 is supposed to do it on demand, I wonder if the GPS has a send timer? Its a eTrax Venture (old yes, but still works. lol
Thanks for your help, just trying to figure this stuff out.
hiegtx
Dallas, TX
#4
Take a look at the entered range of the systems in question.
Even though you have your range set on the scanner set as zero, if the system itself has a range of ten, then it would still be active. The actual range, where systems toggle on and off is the sum of the range on the scanner, PLUS the range of the system.
Alexandria, VA
#6
I did just find on the GPS a tracking log setting page. On it is the ability to change how often it puts the location into the log. I wonder if that also determines how often it will send the location through the interface. I'm adjusting that, and will see the results on the next go around.
troymail
Silent Key
#7
Another HUGE factor is the location information stored with the entries in the RRDB.
On my early experiences, I found many of the entries were not accurate. Many entries get some form of a default setting since most (very few I assume) submissions are made with location and range information.
You may want to take a few local systems, etc. and review their details (lat/lon and range) on RRDB to determine if they are reasonably accurate and test with just a few at first.
I ended up spending quite a bit of time submitting corrections to the location data for my area before things started working like I expected.
ofd8001
Louisville, KY
#8
The simple answer is yes, once the GPS gets a fix on satellites, it continuously sends lat/long data to the scanner.
Why "things" don't go off when you think they should is a "whole 'nother thing". The Range value set in the scanner (in your case 0) is but one variable in the equation of what comes on/goes off and when it does. Site Ranges and Department Ranges are other variables.
You might want to look at the article below:
How it Works: Location, Location, Location
