GR 300 repeater
P25Radio
Oceanside Ca.
I am having a problem reading this monster. Cables are good, Motorola RIB is supplied with a good clean 9V source, I get and error 58. Cables and rib will read the UHF GR300 but not the VHF one. And no I did not save the code plug from years past. Radio does RX and TX fine but can not read it, I need to change the freqs.
cmdrwill
So Cali
Need to use the correct 'software' as the TX RX radios are different. ...IIRC
And several Demerits for NOT saving the original 'codeplugs' .
P25Radio
Oceanside Ca.
All the parameters are correct. as I stated I have a uhf and it reads fine. Same radio just in UHF. My mistake it should be a Radius GR1225 repeater.
cmdrwill
So Cali
Will the gr only has 1 radio in it.
Then it should be labeled GR1225 as you have noted. Or it can be that 'someone' changed parts around.
The model number, serial number, should be on the power amp heatsink.
P25Radio
Oceanside Ca.
It is a GR1225. I missed labeled it. I did remove the radio and I did not see any labels on the heat sink.
P25Radio
Oceanside Ca.
Sorry time to rehash this, Can I replace the radio with just a regular r1225 vhf, if so what are the options or is this a special radio R1225.
