GRE PC-Data Cable (serial) Discontinued
wmbio
Cumberland, Md
Last Saturday at a Radio Shack in Somerset PA they had 3 of these cables. I purchased one so there are still some at shack stores on shelves.
Good luck
Wmbio
GTO_04
Cables for Pro 96 Firmware upgrade.
Will this cable enable me to download newest firmware revision to my Pro-96? If not, which cable do I need and is it available from RS?
As you can probably tell, my Pro-96 has never been connected to a PC! My 396 is though.
GT0_04
GTO_04
Thanks. Is there any difference in functionality between this and the USB cable? USB cable is more convenient for me to use.
GTO_04
Bucko
Marietta, Ohio
Both the serial & USB does the same job. On my system the 20-047 use's com 4 where the serial use's com 1. Using the 20-047 will put the 96/ 2096 in clone mode as soon as you plug it in where the 20-289 does not.
GTO_04
Thanks. I just bought the serial cable, only $5.27 with tax!
GTO_04
GTO_04
I have not seen this question asked before, but when I reflash my Pro-96, will I lose all the frequencies and talk groups that I have programmed in? I know I didn't with the 396.
Thanks.
GTO_04
loumaag
Silent Key - Aug 2014
Katy, TX
Thanks.
Assuming you are talking about updating the DSP, no. If you send it to Ft Worth for some upgrading/repairs, it comes back with the Factory Default settings.
cnmsales
Waynesville, MO
Is this the cable used for the Pro 2051? If so then I should probably get out and get one just in case.
GTO_04
Thanks Lou. I'm just updating the DSP so I should be OK then.
GTO_04
VintageJon
Well, I bought a USB version form GRE at the first of the year. I assumed the Serial cable would be out-moded soon. (Windows is like that, yeterday it worked but today it doesn't)
Thus I got the USB... (hey I have a USB hub and have never used serial port on the 'puter which is dated at this date. Hey, dated 'puter running Windows Pro 2000 still works, for the most part. Works very well with Win96 and GRE USB cable. May You Have Sucess...)
73's,
Jon
cnmsales
Waynesville, MO
Can anyone confirm for me if this is the cable needed on the pro-2051 and if so do they also make a usb cable for my radio.
jlmeade741
Cable Uses
The back of the package says it can be used for 20-196(PRO-2067), 20-466(PRO-2053), 20-515(PRO-99), 20-522(PRO-92), 20-523(PRO-93), 20-525(PRO-95), and 20-526(PRO-96). I have use this cable to peogram the PRO-95, PRO-96/2096, PRO-97/2055, and PRO-99 using WinXX software. I also have used this cable to program PRO-94 and PRO-2051 using Scancat Lite software.
