GRE Super Amplifier
K7MRT
Keller, TX
Been looking at the www.greamerica.com webpage and see a Super Amplifier for Handheld scanners. The story is you put one of these units on your BNC antenna connection, and then put the antenna onto the amplifier. Supposedly increases signal strength up to "40 miles".. Anyone know if this thing is legit or am I hearing a huge sucking sound directed towards my wallet? ($54.99...plus shipping)
rpowley
Rowlett, Texas
I use one and it can pull in some of the more distant signals, especially in rural areas - it also amplifies static and other garbage in high RF areas. All in all it, at least to me it was worth the investment.
ScanDaBands
Banned
State Line
I use the base model (3001) and I LOVE IT......works very well over the whole band spread.....
Colin9690
Airport Operations
Lewis Center, OH
A question for the Super Amp users, do you know if Radioshack still sells these in their stores, or do you need to buy them off the GRE site? I haven't seen them on the Radioshack site for a long time.
ScanDaBands
Banned
State Line
KCChiefs9690 said:
Ok, that's what I thought. They dissapeared off the site a long time ago.
Sometimes if you're lucky enough a store might have some left....at a closeout price.....I bought a 2032 a few years ago for 69.99 they had on the shelf. :D
charles400
HALIFAX COUNTY,NC
Gre super preamplifier designed for handheld scanners
I HAVE USED THIS PREAMPLIFIER FOR OVER 2 YRS.
I CAN HEAR A 800mHz TRUNKING SYSTEM OVER 45 MILES SOUTH OF ME .
I USE THE RADIO SHACK 400mHz-800mHz HT ANTENNA ON TOP OF THE PREAMP.
THIS ITEM WORKS WONDERS WHEN YOU LIVE AWAY FROM THE DESIRED TRUNKING SYSTEM.
IT DOES NOT WORK WITH AN ANTENNA MOUNTED OUTSIDE.
I WOULD PURCHASE THIS ITEM AGAIN.
CHUCK, N4UED
kb8rvp
Michigan
I have a GRE Super Amp used if you are looking for one. I have never used it much in my area because everything I listen to is so close. Just send me a PM if interested.
Mike
raisindot
Mike
NOW you tell me, you gunkie, AFTER I just bought one new from Universal! :)
Suzie
raisindot
Been looking at the GRE America, Inc. - grecom scanner receiver, lcd modules, spread spectrum radio, wireless bridge, scanner antenna, scanner pre-amps. webpage and see a Super Amplifier for Handheld scanners. The story is you put one of these units on your BNC antenna connection, and then put the antenna onto the amplifier. Supposedly increases signal strength up to "40 miles".. Anyone know if this thing is legit or am I hearing a huge sucking sound directed towards my wallet? ($54.99...plus shipping)
Yeah the thread is two years old, but since it's been resurrected, I was convinced by it to try one of these. Got it from Universal Radio for $53 plus shipping.
I was very skeptical at first--couldn't see how an amplifier would help bring in signals.
After an hour with it, I'm a total convert. I'm using it with my PSR 500, trying it with my RS 800 antenna and the Diamond RH77CA.
With 800Mhz trunking 'hits' are happening far more often, and the signals are nearly all 4 bars instead of the 2-3 bars I generally get. I live in the western suburbs of MA and it's bringing in many more MA state police trunk hits than it did without it. It's also bringing in a larger number of hits from the Worcester trunking system (which is about 30 miles away). It isn't really bringing in many of the city of Boston or Cambridge trunking hits I was hoping to hear, but maybe that's the extent of its range.
On VHF-Hi, the thing totally shines. Before, I could up aircraft signals okay--usually one hit every minute or so. With the GRE even the RS 800Mhz antenna is picking up occasional aircraft transmissions, and with the Diamond I'm getting 5-10 transmissions per minute, and nearly all are 3-4 bars in strength.
Same results with UHF--nearly everything is coming through at 4-bar strength.
Surprising, it's causing very little overload. Generally, I have manually attenuated the VHF 'static frequencies' and this helps stop the bothersome stuff. Also interesting is that it improves reception even if you don't turn the DC power on.
Considering that I really dont' want to put up an external antenna, the GRE is nearly the next best thing. If I have any quibbles with it, it's with the tiny screws you need to dig out to put the battery in, and it's very awkward to put the battery in so the cover goes back over the lead wires. And, if you use it with a handheld scanner, you definitely need to prop it up with something so it won't fall over. Oh, yes, and I'm sure I'll waste a lot of batteries by forgetting to turn the thing off. But, otherwise, it's a great investment.
Suzie
Sinister
New Hampshire
The Marada-1100 Amplifier is better and cost less than the GRE model. Check Ebay out I had one shipped for 28.00.
raisindot
Either you're misspelling the name or model or you've got the only of these in the world. I've searched Google and Ebay, and not a single entry comes up for "Marada 1100," or "Marada Amplifier."
Suzie
K7MRT
Keller, TX
I think its Murata...as in Murata Electronics, but even so... I'm not seeing anything they have labelled as
"1100"
Fast1eddie
Crafton Pennsylvania
Suzie, try a lithium battery. Took forever for it's performance to degrade before I replaced it. Works great on my 8200...I get a sharpie and mark where I just notice the signal increase and leave it be.
73,
Ed
IPNFLA124
Currently in Milton, FL, USA - Have lived in sever
I HAVE USED THIS PREAMPLIFIER FOR OVER 2 YRS......IT DOES NOT WORK WITH AN ANTENNA MOUNTED OUTSIDE......
CHUCK, N4UED
Why would it not work with an outside antenna? I have had several pre-amps work with outside antennas, but depending on your bandwidth of the antenna and the quality of your feed-line / coax, it just increases noise, hence the reason most scanners now have attenuation by channel / frequncy or a global attenuation? = No worries?
mcdogg
NE MA
Just Bought!
So I just picked up one of theses things and I have been playing around with it attached to my BC346XT. Does anyone have any tips or tricks on how to tune this thing or how to get the most of it? Does increased gain always result in an increased signal?
Thanks!
