Great Lakes region band opening underway
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
Currently, I am hearing VHF, UHF, and 800 MHz signals from up to 500 kilometers (325 miles) away, and even well into Canada towards Toronto. Currently, I have a very strange data channel for a possible TRS 153.495 MHz. Does anyone have a clue as to who they are?
73's
Ron
Forts
Ontario, Canada
I've been picking up a whack of stuff today from all over the place. One odd system in particular is a Moto control channel on 855.2375. Trunker shows the SysID as 0A28, and the only entry for 0A28 in the database is a system in Florida. I didn't think Motorola used the same SysID for multiple systems? (With the exception of networked systems of course). I'm assuming this system is somewhere in the Michigan/Indiana/Ohio area since that's where my yagi is pointed. I'm also picking up the Emergency Radio Service TRS from Kokomo Indiana this afternoon. According to Streets and Trips, thats a good 470km from my location. Wow!
mikey60
Oakland County Michigan
System 0A28 is located in Wayne County Michigan.
Mike
jagr707
Huge traffic on Waterford's 154.38500 from some place called Seven Hills and Berryville(?). I could not even hear Waterford over the booming crystal clear stuff coming from somewhere. I haven't had much luck finding out anything as there are a million Seven Hills. I thought I head a station identify as kzz448 and another as kvl7 something, but those don't return anything. There is police and fire on this system. I'll keep digging..
J
Edit: Duh the search function works pretty well here. I found out it is in Ohio by Cleveland 154.38500 159.31500 KDP448 RM 110.9 PL 1 Seven Hills Dispatch FM . Makes sense as they use the same PL as Waterford. At least I got the 448 right :p
Thunderbolt
Moderator
Ann Arbor, Michigan
Here is a real mystery. I am receiving Chicago Fire's "Englewood Dispatch," on 159.090 MHz, just like they are next door to me. However, I always thought that Englewood was on 153.770 MHz? Nonetheless, I am hearing both sides of the conversation like they are right in the room with me. How is this possible? Based on what I am hearing, it doesn't sound like they are going through another repeater.
73's
Ron
daleduke17
Bloomington, IL
Thunderbolt -
What parts of Illinois have you been hearing? I know you said in one thread Chicago FD (Englewood), but, I'm curious what elsey you might be picking up.
Thunderbolt
Moderator
Ann Arbor, Michigan
daleduke17 said:
Thunderbolt -
I have been hearing Rockford, and downstate into the Champaign, Effingham areas. I recognized a lot of the ISP traffic on VHF-High band. Gotta love ISPERN on 155.475, hearing them here is a good indication of an intense band-opening.
73's
Ron
W8OSP
Gallia Co Ohio
Yes the 2m ham band has been great the past week. Ive talked from Canada to South Carolina from SE Ohio. SSB 2m is a blast when it opens.
daleduke17
Bloomington, IL
73's
Ron
Awesome. Sounds like a blast. I turned up ISPERN on the console at work, but all I heard was District 9 (Springfield).
K9GTJ
Kokomo, IN
Last night, I talked on the 146.850 repeater in Van Wert using 10 watts from my ground based vertical. I made contacts from Rochester, NY to all over Pennsylvania, Ohio, & Michigan and it was just like I was sitting on a local repeater. I was on several repeaters and we couldn't figure them all out.
denseglow
I don't know if this is concidered "far", but the furthest I have heard is St. Clair County Sheriff on 460.35... it's sad that most public safety around my area are going to digital systems. Say good by to public safety skip.:( I am southwest of Toledo by the way. I got them with a PRO96 with a rubber ducky. However I have CM200 in my car and I heard Stearling Heights PD which my scanner wouldn't even break for.
bigbluemsp
Michigan
Yes 460.350 is St. Clair County..
Also I'm still getting Norwalk PD in Ohio on 460.450 as well as a Lansing area PD in Mi.
Still pulling CHP in on the 39 and 42 bands.
