GREETINGS, Please clarify a dipole question.
colbrz1319
blairstown, new jersey
#1
I have an old Grove Omni Dipole, that I wish to "trim" down for use on higher frequencies then it is presently is. For Example A] Do I cut both rods equally at 17 or 18 inches for VHF -Hi" or B] can I cut one rod at 17 or 18 inches for VHF-HI and the other for 24 inches for 118-136 Aviation Band. Simply put, is it the individual rod length that's important, or the overall length of both rods combined that matters most?
colbrz1319
#3
So, does the radio signal look at the 2 differently cut rod lengths "collectively" for a total of 18 + 24 inches equaling 42 inches...or....as a 18 inch antenna, and a 24 inch antenna, for their respective bands?
